The car travels a good bit- It made it to the Vw Nats in Syd all the way from Townsvegas. wooot wooot
Its all about temps and keeping them cool as possible. On my Vr-T I run a Cryo cooler(nos,Co2) on my intercooler so in the hot days I can spray the the intercooler if its 50 outside the cooler will cool it down(freeze up the front of the intercooler as if it where 20 outside)-thus more Hp) The Awic kit is more efficient plus the componets are aluminium to dispence heat faster and a shorter boost track with lower psi drop.
SLAM.POKE.TUCK.DROP.DOPE!
I don't even know what to write, its awesome.
What else is on the list of things to do?
I have a few other things to put in the engine bay. GT35R with anti surge inlet portmatched to a PP manifold and both have been jet coated. After I get the parts from the Us(a few more lightened pullies,head spacer(9:1),fuel pressure gauge,wideband,and some other bits I'll do all hard lines for the Vac block, Sri,water,oil,catch can a few other things and then its off to get an exhaust made. Thanks for the kind words! Cheers J
thats freakin awesome dude
doing a top job![]()
Thanks M8- whats the dates for Nov again. Hola
nov 15th! dovw
9:1? christ sake!
