Yeap I am happy with them and you can get them with a drop in Hid option-well worth the cash, here is the link-take ur pick CHeers Jay
http://www.parts4euro.com/DCShop/ind...?cPath=1_53_90
SLAM.POKE.TUCK.DROP.DOPE!
Removed the rear carpet on the sides in the hatch and drilled some holes and installed the nut inserts and test fitted a rear TST bar will remove tomarrow and sand it down and paint it BMP along with a SRI and the C-pillar brace
phat..........
How do you open the boot?
i would say solenoid boot pops they are similar to how a cetral locking system works press a button and i unlocks the fiddly part is opening without a grab handlebut the boot is so smooth
http://cgi.ebay.com.au/TRUNK-RELEASE...item518de47a1a
This is a ebay kit
I used the same solenoid that pops the gas door to pop the boot/hatch and it plugs right into the vw harness. I just had to make a few small brackets to mount it. So I can pop it from my factory vw(.:R) remote and the drivers side door switch.
