Sorry mate can't help with tooling.
What you going to run on rear as your BBK ?
So I'm on revision 4 of the mounting bracket (thanks Steve for the milling)and everything lines up and bolts up correctly, So now I can get some new brackets laser cut out of one piece of metal instead of 3. Now I'm waiting for some 315mm rotors to show up. So in the mean time I need to bead blast the brembo ebrakes and rebuild them and then paint all the rear brakes.
Got another set of rear brake lines fabbed up so I can run them from the 4 pot rear caliper through the rear trailing arms to the hard lines. Ohh and the shop foreman approved the upgrading in braking.
SLAM.POKE.TUCK.DROP.DOPE!
yeah what on earth is that for, some ghetto security mod?
Looking good man.
A hyd hand brk umm………….
