Holy foooook that is an awesome pick up!!![]()
Don't tell me that man !!
Love the lobsters. There the right colour too ……….
crazy specs! love it.
I'd go OEM, just my two bob!
With the built bottom end I may throw some cams in and upgrade to a 4" exhaust or at least DP, 44mm or bigger WG and switch to UM software and I have a water/meth kit to install. Gabe says I should upgrade to a hybrid GT40 but Im happy with the 35. Currently power is mid 500 AWHP(21psi) and I'm happy with that because the car is still really quick with no lag and thats how I want to keep it since I want to hit some track events later in the year when I get home. When you start getting around the 700-750HP range then you got to worry about tranny,different clutch set up, and diffs for sure along with some raxels.
I'll keep you gents posted with turbo parts I'll have for sale when I upgrade.
Cheers J
SLAM.POKE.TUCK.DROP.DOPE!
You are a machine Jay. So much big, quality work!![]()
Thanks mate.
Would any one happen to know where I can get the tooling to remove/slide out 5mm the rear wheel bearing on the .:R. I have a puller to remove the rear drive shaft but I need the special tool to slide the outer bearing/hub assembly out about 5mm so I can get the 3 each 8mm bolts out that secure the brake dust sheild. So I can try to finish up the rear BBK.
