Page 37 of 54 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 536
Thread: Jlt-r32
  1. #361
    Townsvegas QLD
    I put the new clutch and To bearing in and Lucas helped me install the tranny to the block and torque everything up.
    Started with the engine bay
    SLAM.POKE.TUCK.DROP.DOPE!
  2. #362
    Oct 2006
    jeebus!
    i think ill be needing a new clutch soon if i keep launching so hard lol
  3. #363
    Sep 2006
    Australia?
    Damm I love you americans <3
  4. #364
    Eastern suburbs of Melb
    Good job! I'll be doing this soon!!!
  5. #365
    Townsvegas QLD
    wheeeew work out is done now coffee date with Mrs JLT then off to the manrage to work in the engine bay.
  6. #366
    May 2009
    North Brisvages
    More great work.
    Always a great read and interesting to see the work you do fella.
  7. #367
    sydney
    blank canvas
    nice one jay,there is a mob in qld ???who are the diff and gearbox masters, peter shelley from cvwc put me on to them i will look it up as my 02a is heading up there for the peloquin at some stage
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  8. #368
    Dec 2007
    Brisbane, Southside...
    Do you feel guilty when you put oil in the motor as the internals are no longer so shiny and clean? I swear I've never seen a more spotless and immaculate engine. If I had the money I would've been doing something like this instead of getting the Renault.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
  9. #369
    May 2010
    Perth
    Nice one Jay,
    Way to make my project look insignificant... hahah
    Looks very good, If you do that GT40 i wanna be the first to hear bout it....
    Cheers, Pedro
    '76 Mk1 LS
    '04 Mk4 .:R32
    '09 Audi S5
  10. #370
    Townsvegas QLD
    I finished up the wire tuck on the passenger side engine bay . I ran the hood switch connector, head light connector and the washer fluid low level switch through the frame rail. I kept the washer fluid low level switch because Im going to use that for the water/meth so when it gets low I will get the icon in the cluster and it will work as factory.
    As for the fuel lines that go to the fuel rail I may do them in stainless steel lines or hardlines since I have plenty of fittings and supplies-well see.
    I still have to relocate the P/S reservoir to the frame rail since it still will be the highest point when I need to bleed it and I'll get rid of the hardlines and do some custom ones along with gettng rid of the line that runs over the tranny.
    I think Im going to ditch the coolant tank and run a inline filler and filter in one that way I still can run coolant to my turbo.
    Tefba Coolant Filters for Classic and Performance Cars and Trucks
    So now I need to grind off all the mounts and stand offs Im not gona use and give that side of the engine bay a good sanding and prep it for some paint. In the mean while Im working the wiring harness arcoss the back of the bay and over to the drivers side.
    Mrs. JLT like what the hell!
    and some progress
