Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: It's turned cold and wet and my heater doesnt work!!
    Mar 2012
    Orange
    Quote Originally Posted by balkanac View Post
    can you tell us how? i have managed to do something with it once (press 3 buttons at once) and it comes up with heaps of info, had no idea what im looking at except for the true speed one
    I just found this
    It may help
    http://pics.tdiclub.com/data/517/Cli...iagnostics.pdf
    EDIT:
    OK I just ran the diagnostic scan and found a 30b and 4fa error (outside temp sensor and recirc flap servo)
    I then ran the actuator test as per the .pdf and it seems to have cleared the 4fa error but the temp sensor will need looking at when I get the chance
    Tomorrow will tell once the car is warmed up.
    2001 Bora 4Motion A work in Progress
    Next up, Big Brake Kit from ECS, Cold Air Intake, Coilovers.
    Aug 2007
    Perth, Australia
    OMG this is gold!! i was looking for this since i got the car, last 5 years
    1991 BMW 318is RED E30
    Mar 2012
    Orange
    Glad I could help, must have held my tongue the right way when I
    Jul 2011
    Those two faults should not effect heat entering the car. The recirc flap motor is common fault after a few years depending on age and a prick to Change!!! it can be done just removing glovebox and looking up the side of the evaporator but very fiddly with the clips and control rods good luck!!! As for your heat problem it's worth checking the two hoses that come out of the evaporator(heatercore)for heat if one side is not hot you may have blocked heater core!!!
    Sent from my iPhone using my fingers.
