Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Issues getting Bora seats into golf gti
    Sep 2012
    Wonga Park, VIC
    Ok after ALOT of screwing around I have found what each wire does what in regards to yellow plug (airbags)
    I have made a wiring schematic, it's your choice whether you want to source out a matching plug or to produce your own connection through direct solder (semi permanent) or a bullet connection (easily interchangeable). The plug did not provide much resistance, so it should not matter what you choose.
    Please refer for future use when people are scratching their heads,
    Issues getting Bora seats into golf gti-wiring-schematic-jpg
    Also, anyone with access to VAGCOM able to reset my airbag error?
    Please note any incidents that may occur through attempted fiddling with airbag connections is done at your own risk.
    Thanks
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by Swainey32 View Post
    Thanks for the diagram! I need to do this asap.
    Sep 2012
    Wonga Park, VIC
    Quote Originally Posted by MCiN7 View Post
    No worries, hopefully it saves people time in the future
