Ok after ALOT of screwing around I have found what each wire does what in regards to yellow plug (airbags)
I have made a wiring schematic, it's your choice whether you want to source out a matching plug or to produce your own connection through direct solder (semi permanent) or a bullet connection (easily interchangeable). The plug did not provide much resistance, so it should not matter what you choose.
Please refer for future use when people are scratching their heads,
Also, anyone with access to VAGCOM able to reset my airbag error?
Please note any incidents that may occur through attempted fiddling with airbag connections is done at your own risk.
Thanks
