Results 1 to 5 of 5
Thread: Issue #2 (Steering Woes)
    Dec 2006
    This is partially linked to Issue #1 (and it could be).
    When I'm at a slow speed, say less than 20kph, and I move the steering wheel left-right-left , it doesn't exactly vibrate, it feels like something is loose.
    In addition I have another problem (issue #1).
    What could be possibly loose to cause this ?
    Any ideas ?
    Oct 2006
    sydney
    Quote Originally Posted by DIDZ
    Any ideas ?
    hey Didier how you doin buddy issue one and two are very similar tyre wear remember i came to your place and you told me it pulled to the left i told you to get a wheel alignment due to the fact it hasnt been done you are getting uneven tyre wear causing vibration tyre noises all sorts of issues get that checked out theres a place on canterbury doing wheel alignments for 30 dollars
    Camden, Sydney
    Yeah and whilst you are getting the wheel alignment done, get em to check there is nothing loose in the front end.
    brackie Guest
    Something worn
    Most (decent) wheel aligners won't touch anything if there's significant wear in bushes, joints, rack etc. They know that they'll have problems getting it right. Ask for a check first. No point in realigning with something worn.
    Dec 2006
    Quote Originally Posted by william
    Hey champ, I'm alright!
    I had the wheel alignment done and it went away, but at the moment it has come back a bit more. I'll check the bushes and see if anything needs tightening.
    If it's the rotors that need machining, is it a walk in/walk out job ?
Similar Threads
  1. Replies: 31
    Last Post: 09-10-2006, 08:34 PM
  2. steering drivetrain and heartache
    By gldgti in forum Mk1 Golf
    Last Post: 04-06-2006, 09:25 PM
  3. Rack Ends solution. steering rack problem fix
    By Edison in forum Mk1 Golf
    Last Post: 10-05-2006, 09:27 AM
  4. New improved dynamically variable steering!
    By Peter Jones in forum Mk1 Golf
    Last Post: 22-11-2005, 09:56 PM
