so all the lower part of the dash has to come out,i took out the arm rest cause im running a power supply to a aux socket in the armrest for a phone charher/whatever
the kit comes with the complete loom and connections and everything you need.
http://www.vwwatercooled.com.au/foru...DSCF0882-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0883-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0891-1.jpg
remove the blanks,cup holder and radio
http://www.vwwatercooled.com.au/foru...DSCF0886-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0887-1.jpg
just start by feeding in the loom into the blanks
http://www.vwwatercooled.com.au/foru...DSCF0885-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0888-1.jpg
because it a genuine retro fit kit,its pretty much plug in as you go,,pin 17 on the light switch for your iluminated switchs,insert 2 wires into the fuse box,no 44 ,for the heated seats and 15 amp fuse,and another wire in into fuse 5,power wire into terminal 30 on the relay board,bolt the earth wire to a ground,and 2 other parts of the loom that have to be routed under along the kick panel both sides and under the carpet to where the loom for the air bag is
http://www.vwwatercooled.com.au/foru...DSCF0890-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0895-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0889-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0893-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0892-1.jpg
and thats about it,just stick it all back together again
http://www.vwwatercooled.com.au/foru...DSCF0968-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0960-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0966-1.jpg
http://www.vwwatercooled.com.au/foru...DSCF0965-1.jpg
there was one problem with the install,because the switches are colour coded with the loom,when it was all together,the drivers side switch heated the the passanger seat and vise versa,easy fix though,the connectors are interchangeable ;)(the kit i think only comes for a lhd car,i could be wrong,but it all works the way its ment to now)
http://www.vwwatercooled.com.au/foru...DSCF0961-1.jpg
but a great kit and glad to have it now,its a bit time consuming but well worth it!
nice work! Wish we got the PD150's here. Sadly not the case :(
cheers for the comments.
vrt was about 1200 as far as i can remember?
No more coffee stained radio
http://www.vwwatercooled.com.au/foru...48500000-1.jpg
Eventually got round to fitting this, it he handbrake sits at a different angle so when it's removed just drill out the mounting holes larger.
And stick it all back together, I removed the seats to make it a bit easier.
And part no's for the bits
One is for the console and one is for the fuel flap release button , the U.S has it in the drivers door.
All the way from Mexico.
And a repair kit for the broken hinge on the centre armrest
Mate that centre console looks good. Nice change getting rid of that stupid ashtray which always break. One thing I suggest is you get rid of that ugly wood grain go for aluminum finish. Here's a pic of mine http://www.vwwatercooled.com.au/foru...a7yredav-1.jpg
Apart from that lovin the build mate looking sweet!!!
[QUOTE=vinnie;864296]cheers for the comments.
Hey mate what kind of centre console is that from? looks awesome!
Quote:
Originally Posted by
grtuned
ugly wood grain
That's subjective lol. I like the fake wood grain!
