Results 1 to 5 of 5
Thread: Intermittent power loss 1.8t agu
    Oct 2010
    I have a agu 1.8t in my golf mk2 running standard tuned ecu. I've recently been getting a misfire that will come and disappear on it's own. I tried changing coil packs with no change. Anyone have any ideas?
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
    Spark plugs but really you should have it scanned first. The ECU is pretty dumb but you never know it might have seen a crank position sensor going off.
    Other favourites are the ignition amplifier. All the broken ones I have seen just died on one cylinder they weren't intermittent.
    Aug 2011
    melbourne
    Spark plugs most likely... But clean your maf and tb first..
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Jan 2014
    Drummoyne N.S.W.
    Clean out all your plugs, and check ICM! just had mine go... Sounds similar! It cuts in and out and sounds a little like you dropped a cylinder.. $60 at a wreckers and don't get conned always go Bosch.!
    Best of luck
    Oct 2010
    Well the problem dropping a cylinder problem never came back, had another power loss problem which turned out to be a the mad sensor being dirty
    Golf mk2 GTi 8v
