Probably one of the switches in the door jam.
Weird thing happens to my Mk4... You shut the door and the dome lights don't go off anymore...
Anyone seen this before ? The small red light in the door trim goes off, just the top lights. The switch on the console up above your head is on "door" or "auto" (can't remember what it says ) I double/triple checked...
Don't tell me it is the door lock module ( drivers side) ; as that is not cheap ?
Many thanks
2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
Yes door module mate , but just to make sure you can hook up Vag com if you know someone and go into measured value blocks and check the micro switch function. Sound like it though. Spray tons of wd into the module mate and open and shut loads of times and see how you go but if its a micro switch module is the fix im afraid. Worst case scenario you can plastic weld a 2nd handie in buts its a fiddle man.
Alba European
Thanks Jimmy,
I might try that as well... I do have vag-com, used it on the Audi but never hooked it up on the Golf, thought it is too basic
I found the plug under the ashtray.
Try these links...(I hope they work!)
http://forums.vwvortex.com/zerothread?id=1015107
http://forums.vwvortex.com/zerothread?id=1542461
Glenn
UPDATE: A bit of WD40 into the door locks and smashing then with a bit of thirst fixed the issue
thanks all.
