Thats why I got the MCD - it plays audio CD's as well.
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
It has a built in TMC box as well!
Functionally it works the same as the MFD but it has buttons as well to switch audio sources, from cd > radio for example. On the MFD you have to go into a submenu to do that!
Also has fast forward and rewind button which the MFD doesn't.
You just don't get that "Simpson-esque" cartoon map display.
The display replicates the one you would see in the dash display (the one in the pic below is just the compass mode display).
The buttons match the climatronic better too
Lot cheaper on ebay too.
Hey all, thought I should reply to this thread that I started and thank you all for the assistance given. So it's all installed and working perfectly with the Whereis map CD V14. Also installed the 6 CD changer into the glovebox without cutting holes anywhere, the changer just sits loose in the glovebox and it's not a problem, closes fine and doesn't skip etc. If anyone requires assistance with something like this in the future, like where to obtain the map CD, let me know
VW .:R32 MKIV DBP 132/200 | VW MFD Ver G, DieselGeek SS Sigma, .:R Center Caps, ECS XAS CAI
Hi YDG - where did you buy your unit?
Photo:
Looks the goods. Definitely going to have to look into this later in the year.
Cheers,
Trent
where did you plug the gps antenna into?, the back of my mfd1 only has connection for radio antenna
.:GOLF:.
Cheers !
.:GOLF:.
