I am sure you'll see the difference with that fitted.
I had mine in at a local engineering place this morning. Having a front mount installed on the A3, in 2 weeks time, prior to the big turbo I have in the shed going on.
Looking forward to that![]()
buy forge smic from ebay or some other place,,,yum yum
remove dodgy standard one!! hehe only joking
remove the two bolts from top,,these are a pain!
there is also a bolt from bottom ,that has a sliding type nut that is attached to a bracket.If you dont know this(like me) you wonder why for 15 minutes why bolt wont start!!
as mine is a 2000 model,its without the sensor.so block hole!
finally make sure all pipework is attached securely and double check bolts!
Finally stand back and admire the new shiny intercooler that no one will see!!!
tada!!!
now for a boost controller!!! any advice?????![]()
yeah its strange,,,feels different but im not sure how.smoother??? what did you notice?Originally Posted by h100vw
Thanks for sharing, now in DIY & FAQ
Only went in today so they could scope the job for 2 weeks time. My car is sill std apart from the Forge DV, TIP and a full 3inch turbo back system.Originally Posted by gpk_gti
gavin
http://www.imagestation.com/4216216/3938200104 big pipe
http://www.imagestation.com/4216216/3938200498 start of downpipe
http://www.imagestation.com/4216216/3938200611 poxy cooler
http://www.imagestation.com/4216216/3938200524 not so poxy cooler
I was looking at smic and the difference is not that huge compared to the stock one. I would get a fmic. What you will notice is less heatsoak after repeated wot through the gears.
Nice one
BLKMJC
got it cheap,, anyway my mission on this car is to modify without damaging or altering too much.as in,with a fmic chopping the bar and front mounts.
The vr6 I had before I copped too much loss as I modified without thinking what happens when I sell it.All the parts that have been removed/changed I have and will replace when the time comes to sell!
hey h100vwwhats that after the cat??
and guys im thinking of changing the plastic grill that is in front of the IC on the bar.Any ideas??
Thanks mikinoz,, forgot about the diy thread,, will take more photos in future!!
There is a flexi joint, sport cat and 2 silencers in the system. I also had an extra bung fitted next to the lambda probe for my wideband data logger.
