Results 11 to 20 of 29
Thread: Installing a FORGE Diverter valve
    Aug 2006
    i installed my turbosmart both ways and it didnt make a difference or any sound diference? is it supposed to make a difference?
    Oct 2006
    the tsmart ones leak so not really, reverse its a bit louder and apparently so ive been told a/market ones u shoudl have it in reverse.
    Quote Originally Posted by fuzion
    Also you should install it in reverse as well.
    What are the benefits of doing that? I can't see any, it doesn't fit as well and pressurised air is on the side of the piston and can't leak past when fitted as stock anyway.
    Oct 2006
    beats me, its apparent when any a/market dvs to be installed in reverse so ive been told by Forge Direct, GFB and other suppliers as well.
    its fits exactly the same, otherwise theres something not right there? both gtis we have are fitted reverse..
    gpk_gti Guest
    conversation with FORGE reseller in the states,and owns a really quick 1.8t jetta,
    qoute----
    gpk says:
    have u heard of ppl puting their diverter valve back to front?
    says:
    reversing the DV
    says:
    yeah
    gpk says:
    wat does that do?
    says:
    they think its got a better sound.....
    says:
    and better response
    says:
    ....yeah, OK
    Gpk says:
    u believe this?
    says:
    if it did
    says:
    then why wouldnt the manufacture do this from the start?
    gpk says:
    exactly
    says:
    Because the Forge 007 is just a souped up version of the origninal BOSCH
    well thats my philosophy as well,If it was meant to go in reverse why didnt the manufacturer specify that on the their website and in the box?
    everyone has the right to decide exactly how they do things with their car.you want to put your gearbox back to front or install 4 intercoolers or whatever ,its your choice.
    Oct 2006
    wow, im running my intercoolers upside down too, all 6 of them lol
    i was told by the VP Chainey to run them in reverse....
    Forge direct told me this, not from some reseller and im passing the info on is all. Run it anyway you like realistically as you said, long as your happy with how pretty it looks in the end :p
    and its a "souped" up version, wow!.. the oem bosch dv is plastic and collapses, disintegrates and wears out very quickly. GFB, Forge, Bailey, TurboSmart, etc are aftermarket ones usually made from high quality alloy/steel and can be serviced for obvious reasons and can also hold much larger boosts as well. hence why forge for example have difference springs for different feel on throttle/boosts.
    gpk_gti Guest
    you dont give up do you.
    Oct 2006
    Quote Originally Posted by gpk_gti
    was just explaining it in detail for people who dont understand whats the difference/why bother to change..
    Jul 2005
    Newcastle, NSW
    Thanks boys, you both have provided valuable input into the forum, however there is no point making fools of yourselves by arguing amongst yourselves.
    'No man wins an argument on the internet' - confusius
    If you object to someones perspective, leave the thread alone if there is nothing positive to say about it. If you want to share a different 'objection' I suggest beginning a new thread.
    I am not going to cull your posts - I respect you will find middle ground - thanks!
    Aug 2006
    Skye, Victoria
    Did you get your different springs as well? I'm sure you've done your research and realise each spring is for a different amount of boost??
    I'm not 100% sure and correct me if I'm wrong but i think you'll find that the spring will control how much vacuum is needed to open the valve, tighter spring and you need more vacuum to open it. so at idle the valve is shut and only when the throttle snaps shut i.e during a gear change the valve opens.
Similar Threads
  1. Installing a FORGE turbo inlet hose
    By gpk_gti in forum Mk4 Golf & Bora and New Beetle
    Last Post: 02-08-2007, 12:31 PM
  2. DV (Diverter Valve)
    By srbsta in forum Mk5 Golf & Jetta
    Last Post: 03-03-2007, 01:55 PM
  3. installing a FORGE smic
    Last Post: 10-02-2007, 08:49 PM
