Results 1 to 5 of 5
Thread: inner cv joint or complete driveshaft
    May 2012
    I need a left inner cv joint for my 2000 model 2 litre. If you where i can get one from or the entire driveshaft. Thanks guys.
    Feb 2010
    Launceston, tas
    you can get them rebuilt at any driveshaft/CV reconditioners, or new oem shaft from the dealer will set you back about 700 or 800ish i think from memory, or you can go cheap aftermarket(which i don't recommend)which are probably half the price. I say go to your local wreckers and look for a second hand OEM one.
    May 2012
    thanks mate, went to VW dealer for a good price. all good, just need to fit it when I get it.
    Feb 2010
    Launceston, tas
    May 2012
    have replaced mk1 mk2 mk3 and mk4 should be the same. I am only replacing the inner cv so a little more work than the u-tube guy. you right about saving some bucks.
