Hi Levo,
I had a MK4 Golf, 1.6L (AKL), with a DUU gearbox. The gearbox shot a rivet through the case, and stuffed it.
After many quotes, including 2nd hand gearboxes, 'reconditioned' gearboxes, 're-built' gearboxes, etc. I ended up buying a GTI 1.8T engine, gearbox, ecu, driveshafts, subframe, etc to swap all from one driveable write off. The 1.8T parts cost me about $1600, I also bought parts for a water pump/timing belt etc replacement while the engine was out, before install to mine, $400, and then the labour would've cost me about $2000 for the swap, which may be more expensive if you only give them parts instead of 2 perfectly working cars.
All up about $3500-$4000. A lot of money, but a reconditioned gearbox + clutch + install was almost the same, and I would've been still stuck with the wussy 1.6L engine! I'm MUCH happier now.
Also, Clarkee has a properly rebuilt 1.6L gearbox for sale! I would've bought it for mine, but it didn't match & I'd already gone ahead with my expensive transformation.
In hindsight, I should've bought a 2nd hand gearbox & sold the 1.6L car, then maybe bought a gti, but I'm happy where I ended up, it just cost me a little more. If you are able to do all the mechanical/labour, you will save yourself generally half the cost on either option.
Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
