Results 1 to 3 of 3
Thread: Indicators not working
    Dec 2019
    Hi all,
    I have searched this and think I found the solution but symptoms didn't completely match what is happening to me.
    Yesterday my indicators stopped working. The obvious fix is that the hazard relay is faulty and needs replacing but before I drive round trying to find one today I wanted to check on a couple of other things.
    Hazard and alarm flashes still work as normal.
    1. The left indicator dash light is staying solid when I turn the ignition on.
    2. The high beam light on the dash is on even though my high beams are off.
    3. Neither left or right indicators work.
    All signs point to a faulty hazard relay but just wanted to double check due to the above couple of anomalies.
    I wired up a new boost gauge to the light switch harness yesterday but I'm pretty sure it's unrelated as the high beam dash light has come on before without high beams being on
    Thanks in advance for your help.
    Dec 2019
    Turns out it was just the fuse, derp.
    High beam dash light is still stuck at on though even though the high beams are working on/off as normal.
    Tried searching but no solutions.
    Any suggestions?
    Apr 2014
    Penrith, NSW
    You might be able to clear this with VCDS / Vag-Com...
