You can compromise grip by going overboard on anti-roll bars - while excessive body roll does make the suspension geometry less than optimal with camber changes, excessive roll stiffness reduces compliance which is hugely underrated on this forum in its contribution to tyre grip. High roll stiffness may give the car a go-kart feel (especially if you increase the rear roll stiffness relative to the front) but can reduce wet grip and make for unpredictable break away behaviour.
Read the links in the post that I have linked in my 1st post as the discussion in there is primarily about the Mk3 and Mk4 Golf platforms.
Transient body roll is more upsetting to a car's response and quality dampers (which you don't get in cheap coilovers, so be prepared to pay real money for decent ones) will control this and, alone, will improve handling and grip.
If you do decide to get coilovers, make sure they don't have a maximum height that is excessively low - some have a minimum drop of 40mm over stock.
Resident grumpy old fart
