Results 1 to 4 of 4
Thread: Immo light - fast blinking
    Apr 2011
    Berwick, Victoria
    Hi all - attempted to code 2 keys tonight with vagtacho but failed to do so.
    After the old keys were deleted - the immobilizer starts blinking at a faster pace than the normal 'immobilizer activated'.
    The light will not turn off - just stays blinking rapidly.
    Has anyone experienced this before?
    I've noticed that there's a ground wire near the ignition barrel that has been cut - is this supposed to be connected to a pin on the barrel? I can't seem to find a pinout or a good reference picture.
    Thanks - Matt
    Mar 2013
    Brisbane QLD
    If the car was running before you started to code another key then wiring will not effect your coding...not sure how good these after market coders are...are your keys genuine? Sometimes even at the dealer coding keys can be a issue at times....and thats with the proper online server to germany...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    I take it you have 1 old key and 1 new....try just recoding the original key on its own
    Apr 2011
    Berwick, Victoria
    Got it sorted - wiring was incorrect @ the reader coil
