after elimination im pretty sure my ignition control module is stuffed. does any one know of anyone wrecking or selling one?
need for a 99 mk4 golf gti 1.8t agu engine. part number is 4D0 905 351
swapped coils and spark plugs around and made no difference. not sure what else to check but cylinder 3 is down
and these seems only culprit
i pulled the coils and spark plugs out and changed their location but still same cylinder not working.
Ryan, I have a newie I can send you. Buy it off me/get me another if it fixes it or send it back if not. It's a common failure.
Can express it tomorrow.
fitted one yesturday...its a bugger as you get a voltage at the coil which puts you off track...unless you scope the voltage to see the pattern is wrong from the ignition controller on the airbox! little buggers....
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
cheers Gav, have sourced one from euro revolution, see how it goes![]()
