Results 1 to 6 of 6
Thread: ignition control module
    May 2012
    Coffs Harbour, NSW
    after elimination im pretty sure my ignition control module is stuffed. does any one know of anyone wrecking or selling one?
    need for a 99 mk4 golf gti 1.8t agu engine. part number is 4D0 905 351
    swapped coils and spark plugs around and made no difference. not sure what else to check but cylinder 3 is down
    and these seems only culprit
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by big_tedman View Post
    Have you swapped your leads to check them?
    May 2012
    Coffs Harbour, NSW
    i pulled the coils and spark plugs out and changed their location but still same cylinder not working.
    Ryan, I have a newie I can send you. Buy it off me/get me another if it fixes it or send it back if not. It's a common failure.
    Can express it tomorrow.
    Mar 2013
    Brisbane QLD
    fitted one yesturday...its a bugger as you get a voltage at the coil which puts you off track...unless you scope the voltage to see the pattern is wrong from the ignition controller on the airbox! little buggers....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    May 2012
    Coffs Harbour, NSW
    cheers Gav, have sourced one from euro revolution, see how it goes
