Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Idle issue - Golf GTI
    Nov 2009
    Melbourne, Victoria
    Hey all, I've recently bought a 2000 Golf GTI as a get-around car. Love driving it so far although I've noticed the RPM will fluctuate up and then back down about 50 RPM, does the same when Aircon is turned on. I tried removing the MAF sensor connector, still did the same thing and of course didn't produce any power while driving.
    Other than that the car drives well, comes onto boost quite hard, power seems to teeter off at about 4,500RPM.. Hope this is normal?
    If you guys have any ideas that would be great.
    Thanks,
    Miha.
    Jul 2007
    Brissy
    That hiccup in the idle is common on chipped cars. Has yours being chipped ?
    Other causes are vacuum leaks.
    Nov 2009
    Melbourne, Victoria
    I don't believe it's being chipped, it's pretty standard all over.
    Dec 2007
    Auckland, New Zealand
    I had/have this issue 2 replaced MAF disappeared for a while but came back last week Thursday with avengence 2 the point while idling it would stall and hesitate 2 start. Couldn't find any leaks/ anything unplugged. As out of the blue as it started it so 2 have disappeared. Vagcom didn't pick up anything either.
    In most cases as advised it's MAF/ vac leak. But they do suffer from Gremlins every once in awhile
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Nov 2009
    Melbourne, Victoria
    Thanks guys, I'll take the MAF out tomorrow and give it a clean... Plus recheck all the vaccum hoses. Hopefully that'll fix it after I do a reset also. If not, maybe I'll look for someone that's got a VAG-COM and wouldn't mind looking if it's bring up any errors before I purchase a cheap ebay item... That in it's self will give me problems I'm sure..
    Guest0608 Guest
    Quote Originally Posted by Miha View Post
    Thanks,
    Miha.
    Could be your throttle body needs a clean out, I had a GTI turbo in the uk and found a boost and poor idle fault, took me ages but worked it out to be the throttler body, removed the whole throttle housing and cleaned out with a clean lint free cloth and some brake fluid, didnt look that bad, just had a thin film of oil on it, refitted and re-adapted to the engine ecu, and never faulted again............VW......
    i'd clean the throttle body before cleaning the MAF. the MAF is delicate so i wouldn't touch it unless you know it's the fault...
    Nov 2009
    Melbourne, Victoria
    Quote Originally Posted by McDub View Post
    Thanks, I'll give that a look first!
    Aug 2007
    Perth WA
    Was going to suggest the throttle body as well, since I've had that cleaned on mine. Just make sure if you do it yourself, that you run through the realignment process with VAGCOM once you connect everything back up.
    http://www.ross-tech.com/vag-com/cars/vwmkIV.html
    '04 BMP MkIV R32 #144
    search getnew
    Aug 2007
    Yeah clean it and re adapt, 1st ive heard of the idle hiccup after a chip????
    The throttle body is prone to gumming up and it upsets the base idle. Please open the butterfly with the throttle mech, and dont just push it open on its own, this will stuff up the potentiometer in the throttle body, went to the aid of someone lately who did jjst that and killed the throttle body
    Best to know before hand
    Jmac
    Alba European
