Results 1 to 10 of 17
Thread: Idle Increase when coming to a standstill
    Jun 2009
    My car will most of the time increase about 50rpm or so, after i have come to a standstill. I can hear and feel the increase. The fuel consumption metre jumps from the usual 0.9L/100Km to 2.0L/100Km. It increases for a period of about 7-8 seconds and then goes back down to normal.
    I think this happened after I cleaned the air filter which was a carbonio with a cone pod filter. Incidently, the filter wasn't changed for 2 years or so.
    Any help would be appreciated.
    Thanks a lot.
    Justin
    idle problems can sometimes be the MAF, so hopefully you didn't play around with it like i did...
    Jun 2009
    hehe
    Yeah, i read your thread thouroughly!
    Apr 2008
    Try turning your A/C off and see if it still happens...
    Nothing to see here...
    Jun 2009
    it was off.
    i don't use it much anyway.
    Jul 2005
    Newcastle, NSW
    At night with the lights on or all the time?
    Camden, Sydney
    Also try turning the steering lock to lock.
    The p/s pump has a switch on it that can adjust the idle.
    Jun 2009
    Quote Originally Posted by mikinoz View Post
    all the time!
    soemthing to do with electronics, the Air fuel ratio must change when car is idling, and some reason it isn't doing it properly.
    i don't understand how that will be related.
    the P/S does have a pressure relief valve... but I am not steering at any angle when this problem occurs.
    Jun 2006
    Orange NSW
    The PS pump puts load on the engine, so it has to increase the throttle position to take the extra load and stop the engine from stalling when you turn the wheel if the engine is at idle. If you have a dodgey or sticky switch, it could be staying engaged, hence the increase in RPM..
    Nov 2006
    Brisbane Qld
    Can you hear a sort of whistling fan noise?
    Could just be the secondary air pump coming on.
