Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
Thread: Idiots guide to Performance CHIPS
  1. #21
    Oct 2006
    Quote Originally Posted by torque View Post
    Well, with enough money and time of course you can achieve anything, but when you draw the line you could have probably bought an S3 for that ... Unless you do all the work yourself which not many can do.
    And then is the question of reliability.
    Or alternatively you can have a 400+hp S3 and have reliability as well!
  2. #22
    gpk_gti Guest
    isnt the turbo gone?
  3. #23
    Nov 2007
    Melbourne, Australia
    Quote Originally Posted by fuzion View Post
    that's what I am trying to say to ... But they learn it the hard way unfortunately.
    2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
    2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
  4. #24
    Nov 2007
    Quote Originally Posted by balkanac View Post
    does anyone have any experience with chipping an R32? There is a way of getting 200kw out of it and thats what i want, just don't know how
    22Nm gain (on the paper) :
    http://www.goapr.com.au/products/ecu_upgrade_r32.html
  5. #25
    Aug 2007
    Perth, Australia
    i already have the intake and the flapper mod on the exhaust (which doesn't help much, i think). I had turbo cars and i hate the lag, thats why i want to get 200kw out of the NA engine. I think it would be just right. if i get it chipped with the APR chip, it should be close to 200 and i think the exhaust should get it there. But i dont really want to loose the sound that it has now
    1991 BMW 318is RED E30
  6. #26
    Aug 2007
    Perth, Australia
    Quote Originally Posted by DubSteve View Post
    Balkanac, you can't use that cause of the chip being suited for a mk5 ECU
    Why not, the engine is exactly the same, they got more power from MK5 with a less restrictive intake manifold. I dont think the ECUs are any different, but i could be wrong
  7. #27
    Oct 2006
    balk, ian from rennenhaus's stock mk5 r32 is also on there for comparison. have a look.
    aussiejimmy from vortex got some good readings, so did powerofcosmic too or there mk4 r32s as well as the quarter mile times
  8. #28
    Trying to answer Balcanac's question on the R32 in particular & difference between MK4 & MK5, but also some examples on N/A tuning.
    The MK5, although based on the MKIV r32 engine has a quite different intake manifold (enlarged), right through the MAF size & airbox design. It also has different exhaust manifolds & catalyst setups as well. the ECU's are similar, but the MK5 uses an ME7.1.5 ECU which supports full canbus, the MKIV has none. There are some changes in the emissions system as well. Most of the extra power comes from the intake side on the new R32 (in stock form)
    We used 3 new R32's for 9 weeks of testing last year & around 30 dyno runs in different configurations.
    Both the MKIV & MKV suffered from a power dip / flat spot (well documented in the MKIV's) which was part cam timing & intake manifold related, but when our software is applied, it elimates it and makes the power curve nice & straight. Why the factory did not fix this, we don't know.
    You can see it on the stock runs, & stock with headers / exhaust / airbox - but as soon as you add the software its gone. We also tested a vehicle with a full cat back system & one without.
    Now all these dyno's were done before & after, same dyno, same operator etc, and we repeated them with other R32's with ease.
    Also for fun, there is our 3.4 N/A Cayman with effect of software & exhaust, and this week, we did a new BMW 130i before & after software.
    All these are 6 cylinder N/A motors - quite interesting!
    I'm sure the other boys in the thread recommending products have before & after graphs of cars to show the difference as well.
    And Porsche Cayman, stock vs Software vs Software + full exhaust
    And a 130i for fun!
  9. #29
    Aug 2007
    Perth, Australia
    so i was wrong
    Which software did you use on these cars? Is there a version for MK4 R32s or is just the new ones?
    If im reading the graphs correctly, software, headers and airbox gained 15kw at the wheels. Can something like this be done to my car? i think that this will bring it up to 200kw at the flywheel.
    Sorry for all the questions and thanks for all the info
  10. #30
    Nov 2007
    Coffs Harbour
    actually answers alot of questions interesting
