Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 142
Thread: I did it - I now drive a 2003 Bora V6 4Motion
  1. #61
    ireland
    so the exhaust manifold?
    VF Stage1 Supercharged V6 4motion Bora
  2. #62
    Apr 2008
    Quote Originally Posted by Shane View Post
    Basically, yeah. Extractors generally replace the stock cast exhaust manifold.
    What does "throw a cel" mean anyway?
    I hadn't considered the weight of the stock R32 discs. After I wear out the first set of discs, I'll see if a two-piece replacement part is available.
    Regarding the 17" wheels, these:
    Nothing to see here...
  3. #63
    ireland
    Never seen those wheels before!
    These are brands hatch
    these are long beaches (these were actually on my bora when i bought it!)
    just some food for thought,throwing s cel means that the "check engine light" would come on,it has been none to happen with soem sport cats etc.
    To answer a question you a while back unfortunately i didnt do a before and after dyno run to compare the exhasut-im raging i didnt,the power gains were pretty evident though,dont under estimate a good panel filter either!!
  4. #64
    Apr 2008
    Ah, OK! Thanks for the explanation.
    I've got the 16" brands hatch wheels now (shots are on the second page of this thread).
  5. #65
    ireland
    sorry my bad im in work and pics are blocked by filter! grrr!
    If you are hell bent on 17's i would go eith long beaches or santa monica II's
  6. #66
    Apr 2008
    No worries - and that's a rotten filter if it blocks all pics!
    I'd like to stay as OEM as possible, and the 17s from the Bora Sport fit over the R32 brakes apparently - that's why I was going with them.
    If I have to go for something else, I'll save up and get lightweight 18s I think, unless a set of R32 wheels pop up somewhere.
  7. #67
    ireland
    Any OEM 17" wheel will fit over the R32 discs,so don't limt your options just yet.
    Im all for keeping it OEM though.
  8. #68
    Dec 2008
    melbourne
    Hello,
    Was wondering what the problem was with the misfiring, im having the same problem. Removed the spark plugs, cyl. 2,4, and 6 plug gaps were around 2mm, 1,3,and 5 were the normal 1.1mm or so. Did you have similar issue..? any advice would be great!!
  9. #69
    Apr 2008
    I've had no misfiring, sorry!
  10. #70
    Apr 2008
    Well, it's been a while, time for an update.
    I have the R32 brakes. The discs are worn and I'll probably replace them, but not with VW OEM ones @ $580 a side! The calipers themselves are in good nick, they'll just need a clean-up and the'll be good to go on the car.
    Under the VW R-Line wheels I've got coming. They're the same design as the 18" wheels that came on the Mk IV R32, but in 17x7.5, and apparently will fit over the R32 brakes (w00t)!
    I've also purchased a set of K-Sport coilovers which I'll be having put on the car. At the same time as they're put on, all the suspension bushes that are shot will be replaced (strut top and lower control arm bushes at the front at least). The bushes should fix the terrible camber issues I have at present (tyres are almost shot).
