Results 1 to 10 of 12
Thread: Hpa Short Shifter Broken! Grrr
    May 2007
    Moonee Ponds
    I find that you can rush the gears with either setup. You have to keep in mind the box was built to be shifted at a certain throw, so I just shift at the same speed I would with the normal throw and have learnt where the box needs tlc when shifting. But having said that, the short shifter certainly makes it different to drive and sometimes I just love how short it is!
    Gearbox rebuild ? you dont like the HPA setup or is it worn ?
    Quote Originally Posted by HitmanR32 View Post
    Yep i would be removing the ****ing thing if i actually had the standard one to replace it with.. its crap
    i like the longer throws it doesnt make you want to rush the gears..
    Car is going in next week for Gearbox Rebuild
    Probably new Bearings and Synchros and more obviously new fluids..
    that and im getting my CVs done at the same time.!
    Feb 2008
    New Zealand
    Not likeing the HPA Set up as the Car doesnt have the German Ponies under the hood..
    and no im not going forced induction
    and i think at one stage some n00b has put non genuine GB fluid in the box
    and it has damaged the synchro rings.
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    May 2007
    Moonee Ponds
    What makes you think that, mine was really notchy and I did the shifter adjustment as per VW specifications and it fixed her right up ? Have you tried re-adjusting the cables ?
    Surely, it would be far cheaper to replace the flud with MT-90 and try that out ?
    Feb 2008
    New Zealand
    ive adjusted the cables many times..
    ive had the Fluid Changed Twice
    the Fact I cant engage any gears without rev matching even when the motor is revolving around 2,500 times perminute screams a little dodge..
    that and every other R i have driven with twice the Kms has nice smooth shifting.. very willing to shift and positive feel
    - 2010 Golf R
    - 1997 Golf VR6
    Feb 2008
    nsw
    i have a b&m shifter if you need one?
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    Feb 2008
    New Zealand
    Thank you for the Offer but I will be reverting back to a standard shifter (i kinda prefer the longer throw lengths)
    - 2010 Golf R
    - 1997 Golf VR6
