ECS Tuning have a pretty good front suspension refresh kit for Mk4 Golfs - worth looking into.
Dogbone and suspension bushes required.....off to post my interest in the group buy threads!
Nothing to see here...
It's actually quite easy, the hardest bit for me was getting the ball joint bolted back onto the control arm. If I did it again, i'd just drop the ball joint while still attached to the control arm.
Tools required:
Socket set
Spanner set
Jigsaw or Hacksaw
Hammer
Cold chisel
2 blocks of wood, 300x50x25
Bench vice
Alternatively, if you have a big socket set (i.e, a socket with the same outer diameter as the aluminium ring on the bush) you can use that to push the bush back in instead of the wood.
I did see a tutorial on how to do it with the wood somewhere.....
