Results 1 to 3 of 3
Thread: How to save $330 - and a lot of stress
    Jul 2007
    Brissy
    Well my car broke down on Tuesday due to the battery top fuse box burning out.
    It cost me a tow and no car for a day.
    Auto electric bill was $330.
    Fuse Box: $117
    Fuses and cables: $35
    Charge Battery: $10
    Labour: $135
    All of this could have been avoided easily.
    I want others to benefit from my bad experience.
    The bolts in the fuse holder on the battery had come a bit loose. This caused arcing and voltage drops which generated a lot of heat and melted the fuse holder and caused the GEN line to burn out. Which stopped the car dead in its tracks, as the battery was no longer getting a charge.
    If the bolts were checked and tight this would not have happened.
    Here is a pic of the damage
    The new part
    OEM part number: 1J0937617D
    Web sources for the fuse box.
    http://www.worldimpex.com/parts/genu...ox_118987.html
    http://www.ecstuning.com/Volkswagen-...ical/ES248855/
    So make some time and check your bolts are tight and avoid this unpleasant situation.
    Lift off the battery cover, pop open the fuse box cover and tighten with a 10mm socket. 6nm ought to be enough. (that is the spec for the bolt on the battery terminal)
    Jun 2009
    thanks, will check.
    Jun 2008
    Ringwood, Victoria
    Will go do right now!!
    Electrical fires in cars are one thing I am really petrified about because they can start with no notice at all, and like you said, just a couple of loose bolts and who knows what can happen!
