I swapped my steering wheel over to a bora one and my airbag lights on. I tried clearing the codes but it doesnt go away. Has anyone fixed this before?
The light is on because you have created a fault some how. You have connected the new airbag? They light will keep coming back until you fix the fault.
You can resistor the airbag connector but if you have an airbag, I don't see why you'd not make it work.
Airbag is connected i even tried swapping over to the stock airbag connector but the light doesnt stop. When i clear the codes the light still stays on it doesnt go away then come back if that helps.
