Results 1 to 5 of 5
Thread: How do I secure these? Where to get clips?
    Albury, NSW Australia
    The door card should be sitting in that channel, so you may need to remove the card to reinstall it properly. You could try and pop it back into place, but if you have a TORX driver it's only a few minutes to remove the door card.
    There are locking clip on the back of the card that pop into the door. The card is also held in place by 6(?) screws, so it should be ok if you're missing a clip or two. If you're desperate, you will be able to order them from your dealer.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Mar 2013
    Brisbane QLD
    you can usually get them back on by twisting the door card into the channel or as above remove the panel complete and slide it in there first then screw it on...window tinters always miss that channel when tinting and refitting! ...VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    In case anyone else has the same problem the door cards don't even need to be removed. You can just lift the "sill" over the metal strip.
    Jul 2007
    Brissy
    Sounds like you have a few broken or missing clips on that door card. Mine has no movement at all unless I take out the 3 screws at the bottom and pop out some clips.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
