Results 1 to 10 of 11
Thread: how to access mk4 climatronic readout and reset service light?
    gpk_gti Guest
    Lightbulb how to access mk4 climatronic readout and reset service light?
    hey dubbers,
    how do you access the climatronic readout?? someone showed me ages ago but I forgot!! and the same with resetting the service light? I forgot that one as well! bloody hopeless!!!
    thanks guys!!!
    gpk_gti Guest
    As for cancelling your service light :
    push and hold odometer button , turn ignition on while holding odometer button . Let go of button and then with the clock button turn clockwise .
    If you dont have the centre display but its flashing in the odometer section you need to just press the odometer button to cylce through the menu (there are 2 service lights to cancel ! )
    Albury, NSW Australia
    Press Fan Down, Temperature Colder, ECON at the same time. IIRC, setting 16 is speed.
    Others are pretty useless.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Aug 2007
    Perth, Australia
    Does anyone know if there is oil temp readout? It'd be nice to have one of those
    1991 BMW 318is RED E30
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by balkanac View Post
    Bloody hell. Way to bring back an old thread.
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    Perth, Australia
    yeah, i know, but i can't find anything. I know i've seen it somwhere on these forums
    May 2007
    Moonee Ponds
    You can view all sorts of information by accessing Vag-com including oil temp and pressure. What I found to be quite interesting is on a quiet road, I accessed the ABS Brakes, knowing full well it would turn all of the Safety systems off. It also turned the AWD system off, which was fun to say the least as I didn't realise how little grip I had up-front when the power is channeled through just the two wheels ! Big black marks here I come lol !
    Apr 2008
    Canberra
    So what do the climatronic readouts mean, i have found list for the MKV but have not been able to find anything for MKIV. Anyone got any info?
    ~~~~____~~~~~~~~~_\_____
    ~~~ /_|__\__~~~~~~ / //__|__\___
    ____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
    Feb 2008
    New Zealand
    Quote Originally Posted by qsilverza View Post
    i wonder if i could do that on a 2wd dyno to run on it..
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    May 2007
    Moonee Ponds
    I am sure you could ! Give it a go... I am not responsible for any damage caused but I doubt you would do anything best to check with a well-known VAG mechanic first though.
