Results 1 to 10 of 10
Thread: holding boost
    Aug 2007
    doncaster, vic
    holding boost
    hey guys just wanted to find out if it was just me...
    my car has been chipped by revo and boost hits 15-16psi, but then after about 4500 to 5500revs it will drop back down almost clost to 10 11psi?
    is it normal or do i have a leak?
    cheers frankee
    Mar 2007
    Is yours a Polo GTI, Frankie? A couple of the items we've found help hold the boost on ours are the SEAT air intake (swap out the Polo one) and a Forge TIP. The boost on mine used to fall off about 5,500 rpm as well ... now it holds firm right through to the red line (and even slightly beyond ... about 6,800 rpm).
    Anyway ... something to consider.
    Cheers,
    Dave
    Aug 2007
    doncaster, vic
    nah i have a golf...does that still apply to me?
    Aug 2007
    Same engine isnt it? Or doesnt the Polo GTI use an AGU?
    Oct 2006
    its normal, it drops down like that on all of them even with the TIP. you will find after 4800rpm the boost drops, you will find it holds more with 3rd and 4th 14+
    Aug 2006
    do your 4th gear on the 1.8t pull betta then 3rd?
    on the highway for me, 3rd gear doesnt move much, so i change to 4th and i can redline it easier.
    Aug 2007
    doncaster, vic
    Quote Originally Posted by fuzion View Post
    thanks man... i wana get one of these " forge tips"!
    Quote Originally Posted by 1DUB2C View Post
    3rd gear is excellent for me but at that speed you wont feel as much as 4th...
    Sep 2006
    It's the characteristics of a turbo charger. They make the most boost once they spool, then it tapers off. It just heats up and doesn't produce as much boost.
    That's the basics of it. You'll see that even with bigger turbos (even something like a 35/40), it will FEEL like they are still making heaps of boost, but it will actually drop down a bit.
    But, since you are wondering, the K03 really does make almost no boost up there. The K04 is a little better, but it still feels like poo past 5500 - the boost gauge will read 10psi.
    Sep 2006
    Quote Originally Posted by FknDubbin View Post
    Slightly different engine, not an AGU. This one has fly by wire throttle, ESP and other little things (I THINK variable valve timing as well).
    Aug 2007
    doncaster, vic
    Quote Originally Posted by Bboy_Sparx View Post
    thanks man i thought that was the case!!
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
