Scan on VAG-COM, clean out throttle body, reset basic settings!
ive noticed that my MK4 gti has a bit of an erratic idle
when i say this it will idle anywhere between 1100 and 1300 rather than the 800 mark which i should, the needle also moves slightly up and down when at the lights
just wondering if there is any way that this can be reset or adjusted?
Yep throttle body sounds right. Have a look here
http://www.vwwatercooled.org.au/newf...ead.php?t=7402
'04 BMP MkIV R32 #144
search getnew
exact thing happend to me... it was just a vacuum leak. fixed the leak reset the comp... no more high idle...
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
Not really, there are alot of members on here that have access to a vagcom. Update your profile so that we know where you are from.
