Results 1 to 4 of 4
Thread: HHEELLPP stripped the thread on the motorside engine mount
    sydney
    any one else had this misfortune.was installing the bfi mount this afternoon and stripped the exhaust end thread out of the section of the mount that bolts to the motor(the old steel bolt into alluminium socket trick). Anyone got one floating around is helicoiling or re-coiling an option.
    havent had a good look at the mount up to the head is it possible to remove without taking off the timing belt??
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    sydney
    this little ucker
    part#038-199-207-H
    I might have one in my shed but it's far too cold to go and look now
    If you have no luck elsewhere, I'll check tomorrow for you.
    sydney
    cheers gav sorted it today
    had a m14 1.5 bolt machined and tapped to m12 1.5 ,and then drilled and tapped the bracket and loctited the sleeve in.
    how it should have been done from the factory me thinks
