What engine is fitted to your car? A scan with VAG-COM would be the best place to start but without that all you can do is visual checks to make sure nothing is disconnected.
Hello alls,
Changed headlight bulbs on both sides today... how car wont run properly... wtf.
removed battery on passenger side, hooked up again, all sweet. drivers side... i heard somethin fall off somewhere when was taking retaining clip off... dunno what fell or anything, or if i hit something, couldn't see nothing on the ground or in the engine bay.
Seems to be having plenty of steam out the exhaust (maybe because of rain, but i drove it yesterday...), and seems to rev to 2 or 3k and stop. Maybe limp mode?
any ideas what's going on, coz i'm out. Dont think is ignition, because revs smooth before stops revving. It stalled/cut as if immobiliser kicked in the 1st time i went to turn it on after changing the headlights too.
Thanks for any help.
standard 2L 8V motor. I dunno if it'd make it t osomewhere able to scan it is the issue. couldnt really drive it down the street even.
Post up where you are dude, maybe there is someone close by that can help you.
Sydney, near paramatta. dunno that could make it to girraween though, before anybody suggests it![]()
http://www.vwwatercooled.org.au/newf...ad.php?t=27504
Have a look on this thread and see if an offer of beer might entice someone round?
PM Pierre (fuzion) I think he said he works around there and I'm sure he'll be willing to help you out considering your dub doesn't budge!!
I'd hazard a guess and say something is telling the ECU to stop acting normally because you unhooked the battery. Maybe some default numbers were overridden with an automatic ECU reset or something/
Thinking throttle body adaptation.
Yep thinking the same- pretty sure if you disconnect the battery, you have to run the TB reset otherwise it will throw codes or go into limp i've heard.
Someone with a VAG COM or similar should be able to do that pretty easily. I've seen a page on the Ross Tech site with the details.
'04 BMP MkIV R32 #144
search getnew
APK engine then, thats strange nothing in and around the drivers side like you mention. If its missing something you should be able to pick up on it via a scan. Cutting out could mean erased learnt values set by the ecu which would req an adaptation of the throttle body.
Good luck
Jmac
Alba European
