Results 1 to 3 of 3
Thread: HELP Sunroof problems in my bora!
    Dec 2013
    frankston
    All of a sudden today my sunroof won't open fully and slide back, if I turn the knob to open all it does is go to a flat position from the tilt ad then get stuck and stay closed, seems like something's stopping it, it's like it tries to open but can't so just gets stuck and stays closed, I can still tilt it though all works good in retrospect
    Nov 2013
    I believe the motor runs until a certain torque level, once it becomes to hard to push the glass it returns to the closed postion. Perhaps tilt the sunroof and have a look at the rails to see if anything is blocking it and if not try lubricating the slide rails?
    Sep 2009
    brisbane
    As above something is probably jammed in the rails or the sunroof itself could have come off the tracks. My bet is the sunroof cover has jammed itself in the tracks. You'll probably have to remove the headlining to inspect it properly, not a hard job but can be tedious.
