The one you bought at Supercrap should work if you use it correctly Slide it onto the filter EXACTLY in the way its shown in the pic on previous page Put the handle downward at 4 oclock and pull upward.
They are designed to self tighten and can loosen some really tight filters I have found.
When you put the new one on smear some of the old oil on the rubber O ring and hand tighten it only.
Check the old filter when you get it off to make sure the old O ring hasnt stuck to the block or you will end up with all the new oil on the ground in a very short time.
Did it ONCE and left sump plug out ONCE as well ROFL
haha well I'm about to give it another go. Will update.
