Thanks guys will have to give it another go today after I get back from the dealer. Might end up using the screwdriver trick as it's quite tight in that area
These ones are at bunnings for cheapish:
Handy for difficult jar lids, too! They're in the section that has power tools, etc.
All the strap band filter removers are terrible..
I bought this one and its the boss... Highly recommendly.
It doesnt crush the filter, even pressure is applied and its like having king kong grip on any filter and twists it off with ease.
Just noticed the ebay store is named wang wang LOL
yeh true... that is one huge oil filter.
The one you bought at Supercrap should work if you use it correctly Slide it onto the filter EXACTLY in the way its shown in the pic on previous page Put the handle downward at 4 oclock and pull upward.
They are designed to self tighten and can loosen some really tight filters I have found.
When you put the new one on smear some of the old oil on the rubber O ring and hand tighten it only.
Check the old filter when you get it off to make sure the old O ring hasnt stuck to the block or you will end up with all the new oil on the ground in a very short time.
Did it ONCE and left sump plug out ONCE as well ROFL
So managed to get the sca strap wrench around but still ain't budging + don't have too much room to work with..
Should I just leave it on with the new oil? Just for a few weeks until my next service?
