Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: Help on removing oil filter
  1. #31
    Pacific Paradise QLD
    Quote Originally Posted by jeremyex_ View Post
    So managed to get the sca strap wrench around but still ain't budging + don't have too much room to work with..
    Should I just leave it on with the new oil? Just for a few weeks until my next service?
    From that pic you have it on the wrong way as if you pull on that it will tighten it wont it. Turn it over and try it
  2. #32
    Aug 2011
    melbourne
    im not far away, send me a PM with your addy and mobile number. i got today off.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
  3. #33
    Feb 2013
    You're right, but still not budging.
  4. #34
    Feb 2013
    Quote Originally Posted by leighaus View Post
    Just Pm'd
  5. #35
    Jun 2011
    Sydney NSW
    If you are having this much trouble, then it points to being hugely overtightened.
    To fit the filter, you need to wipe the seat where it screws on to to make sure there is no dirt.
    With your finger, apply a "smear" of oil to the rubber sealing gasket on the filter.
    Screw it on hand tight. Do NOT use any tools/levers/etc. otherwise you end up like this.
    You should only need to apply a very small force with a strap wrench to unscrew the filter.
  6. #36
    Give it a jerk to crack it off or pull harder
  7. #37
    Jun 2009
    Melbourne, VIC
    Also try using a razor blade to loosen up the seal/gasket, then try and take it off again with the strapamajig.
    Also don't use the screwdriver method unless you're 100% committed to getting it off yourself (or wanna pay more for a mobile mechanic).
    VW Bora V6 4motion
  8. #38
    Erskineville, NSW
    Come in from underneath. Take off the under tray. Use big mofo multigrips (like they open to 125mm parallel). I haven't used an oil filter wrench in years since I bought the big mofo multis.
    Your wasting your time trying to do keyhole surgery from the top.
  9. #39
    Jul 2007
    Brissy
    X2 get in under it, there is heps more room, Your gonna need to get under the car anyway to get the sump plug off.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  10. #40
    Feb 2013
    Cars already up. I'm out at the shops ATM so I might as well buy a pair of multigrips. What size would be optimum?
