Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: Help on removing oil filter
  1. #21
    Arrawarra
    These ones are at bunnings for cheapish:
    Handy for difficult jar lids, too! They're in the section that has power tools, etc.
  2. #22
    Feb 2013
    Thanks guys will have to give it another go today after I get back from the dealer. Might end up using the screwdriver trick as it's quite tight in that area
  3. #23
    Feb 2013
    Quote Originally Posted by leighaus View Post
    where abouts do you live mate, i could help you get it off if you're not too far?
    Live in Mitcham. You close?
  4. #24
    Jan 2011
    Gold Coast, QLD
    All the strap band filter removers are terrible..
    I bought this one and its the boss... Highly recommendly.
    It doesnt crush the filter, even pressure is applied and its like having king kong grip on any filter and twists it off with ease.
    Just noticed the ebay store is named wang wang LOL
  5. #25
    Pacific Paradise QLD
    Quote Originally Posted by Sirocco20348 View Post
    Problem the OP has is that the filter is too long and there appears to be no room at the end to get a puller like that in and put a Handle on it to turn it Well thats what the original photo shows with the hose almost hard up against the end
  6. #26
    Jan 2011
    Gold Coast, QLD
    yeh true... that is one huge oil filter.
  7. #27
    The one you bought at Supercrap should work if you use it correctly Slide it onto the filter EXACTLY in the way its shown in the pic on previous page Put the handle downward at 4 oclock and pull upward.
    They are designed to self tighten and can loosen some really tight filters I have found.
    When you put the new one on smear some of the old oil on the rubber O ring and hand tighten it only.
    Check the old filter when you get it off to make sure the old O ring hasnt stuck to the block or you will end up with all the new oil on the ground in a very short time.
    Did it ONCE and left sump plug out ONCE as well ROFL
  8. #28
    Feb 2013
    Dipstick tubes available from the dealers for about $20. I fitted 1 last week.
    Take your VIN with you so I cam ensure you get the right one.
    And since you'd be throwing the old filter away, I'd follow the suggestions above and stab it with a screwdriver.
    Thanks mate just bought a new tube and dipstick as the plastic on the dipstick crumbled as well. $55..
  9. #29
    Feb 2013
    haha well I'm about to give it another go. Will update.
  10. #30
    Feb 2013
    So managed to get the sca strap wrench around but still ain't budging + don't have too much room to work with..
    Should I just leave it on with the new oil? Just for a few weeks until my next service?
