Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Help please - Shudder when breaking
  1. #21
    May 2007
    Jimboomba. QLD
    Brake rotors
    Hi all,
    A few weeks ago my brakes started to shudder and vibrate up through the brake pedal and steering wheel as well...great I thought, rotors machined/replaced and pads too.....and the pads show little or no wear.
    Then a funny thing happened...it rained.
    I drove around in the rain for a couple of days and since then the shudder/vibration has almost gone...certainly gone enough for me to not consider doing anything with it just yet.
    I am wondering if driving around in the rain could have cleaned/dedusted a lot of the braking components / abs sensors etc?
    Could the shuddering have been caused by a build up of brake dust / glazing of the pads or something else?
    I could have sworn it needed the brakes doing...now I'm not so sure.......
    Has anyone else come across this before?
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
  2. #22
    Apr 2008
    I don't think the extra braking would be worth the expense. You would be into a set of 16 inch wheels, if not 17s just to go over the discs. You'd have the cost of the discs, pads, brackets and possibly the calipers too.
    I reckon the std 288mm brakes are adequate for the car in std form.
    Need 17s minimum, potentially 18s.
    322mm fronts are a pretty beefy upgrade over the 288mm stock setup.
    Nothing to see here...
  3. #23
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by Manaz View Post
    Actually they're a 334mm rotor and I don't think I've ever seen them fit under a 17" rim. I know people have had issues with certain 18" designs that won't fit over the brakes. Also if you have a puncture you will need either the same rim or an Audi 8L S3 space saver which will only fit over the rear brakes and not the fronts.
    Yes you will also need the full setup with Calipers as well as rotors and pads. None of which are cheap. From VW Australia you're looking at $500+ per front rotor and over $300 for a set of front pads. No idea on the cost of the calipers.
    When the dollar was much better I got both rotors delivered from the US for less than $500 and EBC red stuff pads front and rear for about $300 from memory. Slotting the front rotors cost me about $100 locally.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
  4. #24
    Apr 2008
    Hmmm, I've been told (I'll have to confirm, since I have 17s coming) that the OEM 17" Bora Sport V6 4Motion wheels will fit over the R32 brakes. I believe the rears on the R32 are the same as the rears on my Bora V6 4Motion too.
    I'll have to get all this confirmed!
  5. #25
    Dec 2007
    Yeah I'm not 100% sure on it there mate, DUB20V has some knowledge about it as well due to him having that setup before he went to the Porsche brakes. Might be worth giving him a PM. The rears are definitely a lot smaller and will have no issues at all.
