Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Help me with my Mk4 Bora
    gpk_gti Guest
    ray,,,is ASIAN related to you?? seems your typing and spelling style is the same??? hahahahaa
    asian Guest
    yeh nah i was thinkin spacers but im scared its gonna make my wheel fall off and die!!! haha because the ones u get are pretty thick..leaving me poo all to bolt on.. i duno!!! 1DUB2C wat rims ur mate have? its so hard with the dam germans!! ahah all the fitments n offsets are rong wen i like rims!
    can i fit dubs?? i want fakies tho he he
    Canberra
    Quote Originally Posted by asian View Post
    The idea with spacers (if you decide to to that) is that you should use longer bolts not the standard ones. The standard ones have a 28mm long thread so if you use a 10mm spacer you need to use a 38mm long bolt. That way your wheels won't fall off.
    Cheers.
    Snowy
    asian Guest
    ohh i seee... yes that sounds like a good idea.. saves me money i can spend on turbo the beast!! where can i get these bolts? do u reccommend ne type of bolts or should i get em from likeeee where i service my car or sumthin..
    thanks tho
