Any idea what might be going on here?
I have a 2L Mk4, 160km on it and yesterday encountered some issues. I will do my best to describe what was happening:
Lost power in the lower end and when i go to accelerate under load (up hill, from a start or after cruising then giving it more pedal) it lacks power but not only that the engine seems to shake/vibrate .....no smoothness to it at all (i feel it even in the steering wheel the shaking from the engine)
Idles bit rough with the same shakey engine .....again no smoothness
Sounds a bit like an old aircooled now! Idling and under acceleration is a bit put put kind of noise and in pulses.
I disconnected the MAF (this was replaced about 40,000 km ago) and this didn't make a difference so it is something else.
Any insights are appreciated as gonna be about 5 days before i can take it to anyone and need to keep driving.
- You may not post replies
- You may not edit your posts
Forum Rules
