Results 1 to 5 of 5
Thread: Help identifying these
    Dec 2014
    coopers plains, QLD
    Hi
    Are these standard gti calipers? Does the 54 denote the piston size?
    Also are these standard gti carriers? I haven't found any dimensions for the TT carriers to compare.....
    Attached Thumbnails Attached Thumbnails Help identifying these-wp_20150529_18_28_09_pro-jpg   Help identifying these-wp_20150529_18_28_40_pro-jpg
    Dec 2014
    coopers plains, QLD
    Bumped
    From memory the gti (288mm) had 54mm pistons and the 312mm had 57mm.
    not sure if that relates to the number stamped on it or not.
    If i have my wheels off today ill try and grab some part number for you
    Jan 2011
    Gold Coast, QLD
    Help identifying these-uploadfromtaptalk1432987078236-jpg
    312mm left, 288mm right
    Dec 2014
    coopers plains, QLD
    Here is a closer image. The only diff on the image I can see is that the 312mm carriers have a slightly more curved back near the larger bolt holes (on the left hand side)
    I'm pretty sure these are 288's then.....
    Attached Thumbnails Attached Thumbnails Help identifying these-wp_20150601_07_44_26_pro-jpg
