9303 4999 or 9303 4888
so, as we all know, its been raining plenty in the past couple of days....
i was driving my wife to work, and through a massive puddle....
the car wont statr/turn over, theres an oil leak and for extra fun a piece if engine fell out when i took off the Armour to have a look.... and i have no idea what it is!!!
first q, whats golfwagens number?!
thanks!
black mkIV .:R32 #001/200
04 black new beetle turbo
matt black 1970 beetle- low n slow!
big thanks!
alright everyone! time to test your 24v vr6 knowlege!
what the hell is this, and more importantly what did it break off of?
wowwww did a puddle cause that is the sump still there
looks to me piece of a conrod
it was one hell of a puddle- almost a road lake.
turns out it is the bottom of a rod- how it got out ive no idea, and i guess the fragments of alloy that came with it where chunks of sump.....
this is gonna cost a lot
That was what I was thinking - the bottom half of the conrod which goes around the bottom of the crankshaft. You'd certainly know if that were missing - you'd have a *serious* oil leak due to punching a hole in your bottom end - theoretically possible if the car ingested a lot of water (hydraulic lock in the cylinder)...
Are you sure it fell off your car, rather than getting fired up into the underneath off the road?
EDIT: Seems we posted at the same time. I'd have to guess your air intake sucked in a substantial amount of water, and when a piston rose during the compression stroke, you experienced hydraulic lock (liquid water doesn't compress) and that's blown a hole out the bottom of your block.
Time for a new bottom end...
Nothing to see here...
Ooh bugger...
This is going to one hell of a ride. Bad luck there mate. Definitely keep us in the loop on how this one goes.
Maybe time for that turbo kit since you're going to have the engine out yeah?
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Bad luck man, that's a sad sight indeed. Hope Joe can get it sorted out for you quickly and it's not too $$. Did you hit a pothole, or was it just general flooding on the road?
'04 BMP MkIV R32 #144
search getnew
Mate i feel so sorry for you. That is really dissapointing. Hope you can sort something out that isn't too ridiculously $$$.
2010 Skoda Octavia vRS Wagon
