Results 1 to 10 of 87
Thread: help help help!!!!!
r32 uberwagen help help help!!!!! 23-05-2009, 03:58 PM
FJ Steve 9303 4999 or 9303 4888 23-05-2009, 04:06 PM
r32 uberwagen big thanks! 23-05-2009, 04:47 PM
r32 uberwagen alright everyone! time to... 23-05-2009, 07:55 PM
andrew wowwww did a puddle cause... 23-05-2009, 08:50 PM
r32 uberwagen it was one hell of a puddle-... 23-05-2009, 09:03 PM
    Dec 2008
    perth
    help help help!!!!!
    so, as we all know, its been raining plenty in the past couple of days....
    i was driving my wife to work, and through a massive puddle....
    the car wont statr/turn over, theres an oil leak and for extra fun a piece if engine fell out when i took off the Armour to have a look.... and i have no idea what it is!!!
    first q, whats golfwagens number?!
    thanks!
    black mkIV .:R32 #001/200
    04 black new beetle turbo
    matt black 1970 beetle- low n slow!
    Mindarie, Perth (WA)
    Dec 2008
    perth
    big thanks!
    Dec 2008
    perth
    alright everyone! time to test your 24v vr6 knowlege!
    what the hell is this, and more importantly what did it break off of?
    wowwww did a puddle cause that is the sump still there
    looks to me piece of a conrod
    Dec 2008
    perth
    it was one hell of a puddle- almost a road lake.
    turns out it is the bottom of a rod- how it got out ive no idea, and i guess the fragments of alloy that came with it where chunks of sump.....
    this is gonna cost a lot
    Apr 2008
    Quote Originally Posted by andrew View Post
    That was what I was thinking - the bottom half of the conrod which goes around the bottom of the crankshaft. You'd certainly know if that were missing - you'd have a *serious* oil leak due to punching a hole in your bottom end - theoretically possible if the car ingested a lot of water (hydraulic lock in the cylinder)...
    Are you sure it fell off your car, rather than getting fired up into the underneath off the road?
    EDIT: Seems we posted at the same time. I'd have to guess your air intake sucked in a substantial amount of water, and when a piston rose during the compression stroke, you experienced hydraulic lock (liquid water doesn't compress) and that's blown a hole out the bottom of your block.
    Time for a new bottom end...
    Nothing to see here...
