Results 1 to 4 of 4
Thread: Anyone running 18x8.5 et35 front 18x9.5 et35 rear???
    Jul 2012
    I am thinking of getting some new 18" rims 8.5 et35 and 9.5 et35. Has anyone here got that size on their golf? I did check the MKIV Wheel Q&A and the only one closest to the 9.5 et35 rear was trickysimon's 4mo bora - which being an AWD may be different under the arch to my FWD golf???
    So basically I want to know how the 18x9.5 rear rims would go on a FWD car.
    Sorry for the questions which probably have been asked before but any help would be appreciated
    front is all good.
    I need to find the photos of when I fitted up a 18x9.5et20 with a 225/40 on it.
    that fitted but would have been close, so 18x9.5et35 should be fine
    fit with 215/40 and 225/40 too and you should be sweet
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2012
    Cool thanks - I will see how I go
    Mar 2009
    Wagga Wagga
    For what it is worth, 9.5 Et40 is about the limit of what you can fit inwards. I may even have to grind my spring perch a bit.
