Results 1 to 7 of 7
Thread: Help with fault codes
    Feb 2013
    My car has been idling higher than usual lately at random times. It will idle around 800 rpm when warm and uses around 1.0l/h - which is normal, but randomly will jump to around 1100 rpm and uses 1.5l/h when idling until I turn off the engine. When I restart the engine it will go back to normal until it jumps back up again. I plugged in vcds and it shows that when the car is idling normally, it will read 'idle'. But when the idle randomly jumps to around 1100 rpm whilst still idling, it reads 'part throttle'. I'm stumped for ideas.
    The codes I've pulled are:
    00282 - Throttle Position Actuator (V60): Implausible Signal (Cleared but hasn't come back after I drove it around today)
    This is a new one that just popped up
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Any help is appreciated!
    Thanks
    Jan 2011
    Gold Coast, QLD
    Sometimes error codes are related to problems years ago, and when the problem was solved, the error code was not cleared. So if it doesn't come back I wouldn't be worried.
    When was the last time you cleaned your throttle body?
    But according to rosstech:
    00282
    00282 - Ross-Tech Wiki
    01314
    01314 - Ross-Tech Wiki
    Feb 2013
    Thanks mate.
    Cleaned the TB a couple of weeks ago. Removed it and cleaned it again today. Cleared codes.
    Idled normally and shot up again. I think the '00282' code is related to the cruise control system - after the idle shot up, the cruise control wouldn't work. Think it might be a faulty clutch switch. Went for a couple of drives later on - Cruise control working, Idle normal. Weird..
    Mar 2013
    Brisbane QLD
    Clutch switch....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Feb 2013
    Just ordered one from the dealer. Will update if it fixes it
    May 2013
    Darwin
    Quote Originally Posted by jeremyex_ View Post
    Did it fix issue?
    Feb 2013
    Nope. Cleaned the throttle body mechanics
