First off, is there any running issues with the car?
The first thing to do is reset the codes and see if they re-appear. The heating open circuit could be due to the probe being disconnected with the ignition switched on. Not really likely but the ECU could see that as the same fault, if you know what I mean.
Assuming that heater fault comes straight back, I reckon it will, then you would fit a new probe and recheck for faults. If you didn't want to fit a probe, then you would troubleshoot the wiring first to prove the heater power is good or bad.
Thing is, troubleshooting at $80 an hour and then having to fit the probe anyway, could turn out to be wasted money.
I am very surprised your mechanic hasn't offered to fit a new probe?????????????
